Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Driveshaft length and balance
Old 01-31-2003, 02:19 PM
onebadmerc's Avatar
onebadmerc onebadmerc is offline
I need a bucket of arc sparks
Post
Take your yoke off of the driveshaft, slide it into the transmission all the way then pull it back out 1/4 to 1/2 inch. Then take your tape and measure fron the center of the U joint cap in the yoke to the center of where the other U joint cap sits in the rearend. Make sure all four of your tires are on the ground when measuring, the way it will be when your driving it, or your measurement will be off.
