Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Driveshaft length and balance
Old 01-31-2003, 05:20 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
If you slid the yolk all the way in the transmission and measure from the center of the yolk cap to the center of the rear cap and give this to your driveshaft shop, they will add the correct slide clearance. That said, most of them use 1".
Chris
