driveshaft length, don't know what to do??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 08:36 PM
The drive shaft I have now has a 3 3/4" yoke it sticks out of the tranny seal 1 1/2" and the tranny shaft sticks out past the seal 1/4" so I have 2 1/2' ON THE SPLINE. i'VE BEEN TOLD THAT i SHOULD ONLY HAVE 3/4" TO 1" of the yoke shaft showing. Is mine ok or should I have a longer driveshaft? I have one available that is 1" longer should I get it shortened 1/2" so then I would only have 1" between the yoke and the seal?
thanks
Old 08-24-2008, 10:48 PM
You can clearly see where the seal ran for a long time on this yoke. Maybe you can see the wear place on yours and know how far it is supposed to be in. I have always pulled the yoke ALL THE WAY in and then pulled it out 3/4 to 1 inch. That's where they are supposed to run. Then I had the driveshaft made to fit ...
Old 08-25-2008, 06:04 AM
SSedan64's Avatar
thanks
Check here>
http://www.dennysdriveshaft.com/how_to_measure.html
Old 08-25-2008, 08:54 AM
so the way mine is now with 1 1/2 ' sticking out past the seal is unacceptable,right? what will happen if I run it that way?
Old 08-25-2008, 09:26 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
It may not be up on the shaft enough to keep it from trying to rock and therefore cause your seal to leak....if you do not have any problem with leaks or short lived seals...then I would not worry about it.
Old 08-28-2008, 06:09 PM
thanks,Its going all the way into the bushing in the tailshaft,so I think I'll leave it alone and keep an eye on the seal
proper driveshaft length murrsue Transmission - Rearend 3 10-09-2006 12:03 PM
wrong driveshaft length? darom Transmission - Rearend 16 03-23-2004 07:59 PM
TH400 Driveshaft length mark2002 Transmission - Rearend 4 11-22-2003 08:46 AM
Driveshaft length and balance edubois Transmission - Rearend 7 02-01-2003 12:00 PM
Nova Driveshaft Length 68NovaSS Transmission - Rearend 2 01-20-2003 09:19 PM
