Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Driveshaft Lengthening
  #17 (permalink)
Old 07-11-2012, 08:44 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by S10xGN View Post
Could only be the tubing, shaft ends, and labor. As for measuring, I've always put the car up where I can get under it comfortably (making sure the rear axle is fully loaded) then measure center to center on the u-joints with the trans yoke pulled out 3/4" from fully inserted. There are other ways to measure, so whatever you use, be sure to tell the shop exactly how you measured.
Russ
Now when you say rear axle fully loaded do you mean like jack it up in the air and put jack stands under the rear end and place the car weight on it, or just while the vehicle is sitting on the rearend normally.
