Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Driveshaft Lengthening
  #24 (permalink)
Old 07-12-2012, 05:25 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
Originally Posted by timothale View Post
When I need a drive shaft cut down I always look for one that has minimum or NO balance weights from the factory, then you have a better chance of getting a good balance
Very true. If the ends are in straight.. a "good" driveline guy can straighten the driveline. You just need to know what your doing with the heat. All the weights need to be knocked off and start over.
If you ever get a "newly' balanced shaft that has 2 or more weights next to each other that go around the shaft... I would ask them to double check it. That is a NO NO and I see it quite often.
