Driveshaft Lengthening - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2012, 05:53 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Hey Everyone! I didn't notice till the other day that you can buy longer transmission Yokes for driveshafts. I was wondering is this considered an appropriate way to get around having to have your drive shaft sent out to have maybe 2" added to it. I got a driveshaft with my s10 when I got it and go figure its about 2" short. So my question is can I run a longer transmission yoke to make up the difference? I will still measure the total length by bottoming the yoke out in the transmission and then pulling it out .75"-1" and making sure from there the driveshaft bolts right into the diff.
Thanks!
Old 07-09-2012, 09:22 AM
Drive shaft would be as cheep and better i payed $30 and WAS ready in a hour FOR MY K5 with no discount.Just find a drive shaft shop most citys have one!!!
Old 07-09-2012, 09:25 AM
We've seen this a few times, both in our 4speeds and in our industrial applications. There's no set rule. Sometimes its good, occasionally we see problems.
1) The longer yoke can change the angle of the driveline slightly when you stop the vehicle; you may get the 'stop-clunk!'
2) it will change the rpm where vibrations will be imparted; you may see vibrations, you may not.
Now Im sure you'll get people saying "I've done it for years eith no problems" all I can say to that is every application is unique when it comes to dynamic balancing. For my money; Id get a new driveshaft made with your ends, and new U Joints; and have it spin balanced.
Old 07-09-2012, 11:10 AM
I personally agree with AutoGear. When you use a long yoke you are moving the universal joint further away from the transmission tailshaft bushing which can increase any tendencies for vibration. I did it once when I was a youngster and it was fine up to about 50 mph but from there up it began to vibrate. Building a good driveshaft with the correct amount of room to slip is worth the time and effort.
Old 07-09-2012, 01:23 PM
Listen and Learn
Wiki Edits: 7
Thanks for all the replies everyone! I think I will just buy a new transmission yoke and have the driveshaft lengthened. Seems like the better way to go. The last place I had make me a drive shaft it ended up being like $450 and from what everyone else told me that was on the high side so maybe I will try somewhere different this time.
Old 07-09-2012, 01:40 PM
It is always more expensive to have a driveshaft lengthened instead of shortened because they have to replace the tube and weld both ends. If you can find one that is too long all the shop has to do is cut it and reweld it. 450 dollars is more than twice what I have had to pay to have one lengthened though.
Good luck
Old 07-09-2012, 03:57 PM
327NUT's Avatar
$450 ???? they are trying to screw you pardner. I had mine built and balanced at "6 States" truck supply....$190. I had my own front and rear yokes but they installed new U joints. Shop around, some of these supposed "high performance" or specialty driveline outfits think their chit don't stink and gouge the helloutta folks.
Old 07-09-2012, 04:31 PM
Listen and Learn
Wiki Edits: 7
Yeah I wasn't sure if cause I didn't supply the trans yoke or diff flange thats why it was more expensive but I wanna dig up the receipt again and look it over. See if there was something i was missing.
Old 07-10-2012, 08:49 AM
prostreet6t9's Avatar
Differential/Driveline
I've heard Six States does pretty good work. They have really good Differential shops also.
Old 07-10-2012, 08:51 AM
Which Trans do you have? How long is the Yoke your using now?
Old 07-10-2012, 09:08 AM
S10xGN's Avatar
Gotta love a turbo!
Zil,
We get them built from scratch here for $280, all you need to supply is the correct dimensions and what joints you are gonna use...
Russ
Old 07-10-2012, 10:33 AM
Listen and Learn
Wiki Edits: 7
the transmission is a th350. Do you measure from the middle of the u joint to the edge that goes into the transmission? and unsure of the length cause I scrapped the other trans flange. It had broke from the previous owner and he welded it back together
Old 07-10-2012, 10:36 AM
Listen and Learn
Wiki Edits: 7
Originally Posted by S10xGN View Post
Zil,
Russ
Yeah I didn't really think about it at the time because I had been waiting so long to get the car on the road since rebuilding the rearend and rebuilding the engine. But the more I look around something wasn't right. I know the flange for the 8.8 they had to order in which was like $30 and im sure the trans yoke was about $50... so where did the rest of the price come in? This weekend I am gonna dig up the receipt if I still have it and look it all over.
Old 07-10-2012, 11:47 AM
TH 350 1310 26 on 27 1.500 * 5.469 * 2-3-6081X
TH 350 1310 26 on 27 1.500 * 6.417 * 2-3-11071X
TH 350 3R 26 on 27 1.500 * 5.469 * 7812557
TH 350 1330 26 on 27 1.500 * 6.76 * 2-3-12051X
TH 350 1350 26 on 27 1.500 * 6.938 * 3-3-4281X
They are measured from center of the cap hole to the end.
Those are the common numbers.
The Following User Says Thank You to prostreet6t9 For This Useful Post:
zildjian4life218 (07-11-2012)
Old 07-11-2012, 05:07 AM
Listen and Learn
Wiki Edits: 7
Awesome perfect! I will order one of those and then go have a new shaft made with new ends. Thanks for all the input everyone!
"Basics of Basics" Lengthening or shortening a bolt or rod. MARTINSR Hotrodding Basics 10 01-04-2012 07:52 AM
How do i take off my driveshaft?? aztek_warrior Transmission - Rearend 4 05-09-2006 06:52 PM
Driveshaft lengthening 78 monte Transmission - Rearend 8 05-18-2004 06:44 PM
Lengthening shift points in a TH350 Big86inthestixx Transmission - Rearend 8 12-27-2003 06:46 AM
lengthening doors in fibreglass body deuce_454 Body - Exterior 2 09-25-2002 11:49 AM
