Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #16
Old 03-05-2006, 08:51 AM
Chopt 48 Chopt 48 is offline
re: Driveshaft lengths???
I've done a bunch of them over the years but the one I just did for the GMC is the only one that has had vibration problems.
I think that this was due to using a shaft with a dent in it.
We usually take a hack saw and cut through the tube next to the weld. Just cut into it a bit at a time to just cut the tube and not the end piece.
We then put an old ring compressor around the driveshaft to use as a guide to cut the shaft.
Like mentioned above make sure that the ends are in phase and true.
The problem that I have found with using a chop saw is that most of them just do not cut true after being used for a while.
Sending off an order for a new shaft is great but not everyone has the ready cash to put out for one and not all project rigs are intended for high speed driving.
Back to top
This discussion has been added to the Transmission - Rearend Discussions category of the Hotrodders Knowledge Base.
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Driveshaft lengths???"
New Driveshaft Noise bjam2 Transmission - Rearend 6 08-26-2006 11:18 AM
Multi-section driveshaft ckucia Transmission - Rearend 23 05-07-2006 12:01 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 09:20 PM
wrong driveshaft length? darom Transmission - Rearend 16 03-23-2004 07:59 PM
Driveshaft measurement 71gtx Transmission - Rearend 6 01-11-2004 11:00 AM
