Driveshaft upgrade? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2012, 04:14 PM
Driveshaft upgrade?
I'm gonna need a new driveshaft after putting the bigblock in the the 72 c10 the old driveshaft couldn't take it. The bbc makes somewhere around 500hp I have the eaton posi unit and 3.42 gears could someone direct me to a custom driveshaft that will hold up..Any advice/suggestions would be appreciated...Thanks
Old 10-28-2012, 09:17 PM
bigdog7373's Avatar
Of course it's fast
Just go to your nearest drive shaft shop. They will be able to build you the perfect shaft for your truck.
Old 11-02-2012, 04:42 PM
prostreet6t9's Avatar
Differential/Driveline
3-4-8691-1X Spicer part number. 12 bolt Pinion yoke
3-3-4281X Spicer part number.. 1350 slip yoke TH-350
If you upgraded the yokes and did a shaft with 3" .083 wall.. That would make a nice strong shaft.
Old 11-03-2012, 12:09 AM
406 bug's Avatar
9.82 @ 139mph
Got mine thru summit. It's a 3" crome moly made by Strange Engineering; as I recall it was around 200 bucks. You send dementions they custom build.
Driveshaft gasmasher Transmission - Rearend 8 09-02-2005 05:21 PM
driveshaft @#$#@$% KNIGHT07731 Transmission - Rearend 1 11-30-2004 04:51 PM
driveshaft help!! stewwwy1 Transmission - Rearend 1 03-20-2004 10:08 PM
driveshaft upgrade jimmy dee Engine 2 12-21-2003 10:41 PM
driveshaft cavkid Transmission - Rearend 2 04-22-2003 06:09 AM
