Driveshaft woes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2006, 08:48 PM
grapro's Avatar
Last journal entry: Out in the Sun
Driveshaft woes
Just picked up drive shaft for my t5 and it is different from the last one I had this one has a counterwieght on one end and my last one didn't I was wondering what this drum counterweight was for and what drive shaft should I use.
Old 12-31-2006, 09:50 PM
The Maintenance Geek
More than likely the weight is just opposite
the seam in the tube, you do want it balanced,
don't you??
K
Old 12-31-2006, 09:53 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The weight is for balance. Some of them have two or three weights or none at all....just depends on the balance. If its not balanced it will vibrate and shake on ya.
Old 01-01-2007, 03:24 AM
grapro's Avatar
My mistake
I guess I should have said it is like a vibration damper Its 5 inches in diameter and its right behind the front universal.
Old 01-01-2007, 07:12 AM
idahotower's Avatar
Know just enough 2B DANGEROUS!
Seen several like it...
I drive to truck (particularly flat-bed), this meens that I see the underside of way too many rigs every day. I tounds just like you said, a harmonic balancer. It should regulate the balance and vibration to give a really good quiet ride...
700 r4 to 8.8 driveshaft murrsue Transmission - Rearend 12 10-23-2006 11:36 PM
How long is your driveshaft? MotorCityCarMan Transmission - Rearend 1 06-23-2006 06:30 AM
Multi-section driveshaft ckucia Transmission - Rearend 23 05-07-2006 12:01 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 09:20 PM
Driveshaft measurement 71gtx Transmission - Rearend 6 01-11-2004 11:00 AM
