Drivetrain making a pop/click????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2004, 02:44 PM
84Z 84Z is offline
Gas Raper
I was driving normally one day, about 45 mph, and all of a sudden i started to get this strange popping or dull clicking sound. It only happens when my car's in gear and accelerating. When I decelerate in gear, bring it to neutral, rev it, it doesn't happen. When I jam the shifter all the way forward, I can feel the clicking vibrations in the shifter. I didn't get a chance to take a look at it yet, but i'd like to know what you guys think first, thanks.
Old 05-11-2004, 07:09 PM
Jmark's Avatar
Dried up u-joint? And shaking it doesn't count as a test. I"ve seen many of them so tight that they don't move any more, thats why they start poping, and thats usually just before they to BANG!!!!! and drop the shaft in the street!
Old 05-11-2004, 07:25 PM
poncho62's Avatar
Wiki Edits: 5
Yup....that was my thought too.
Old 05-17-2004, 11:18 AM
k2mooch's Avatar
Friend of mine has a '96 F150 XL with the same problem. We thought it was the trans mount at first, but it would be clicking when the engine torqued at neutral, so it wasn't what we thought. Took it to a shop, sure enough it was the U-joint.
MoocH
Old 05-17-2004, 12:16 PM
84Z 84Z is offline
Gas Raper
I thought it was the u joints at first too but after getting it up on a lift, I discovered the u joints were perfectly fine. Then I thought it was either the tranny or the diff, and since the tranny was fine I just decided to open up the diff and sure enough a notch on the pinion had broken off. I wanted to get a new rear end so I guess this was pretty good timing . Anyways, thanks for your opinions.
