Drivetrain Options for big Buick? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2003, 07:10 PM
devioussquirrel's Avatar
Hello,
I'm new to this board..
I'd like to install a modern drivetrain into a '51 Buick Roadmaster 2 dr HT. Any suggestions? I've read a lot of good things about the GM ZZ4 crate engine, but I haven't heard of any installations in 4000+ lb vehicles. Do you think it has enough low end torque to get all that weight rolling? Maybe it's just a matter of carefully choosing a transmission and rear end.
I'm not looking for screaming acceleration. I just want an extremely reliable, troublefree drivetrain that runs on premium pump gas. Something I can fire up and take on a 400 mile trip without worrying. I want enough power to keep up with modern traffic and surprise the occasional rice rocket. I don't mind a little of a loping rumble, but I'd like to keep the engine somewhat civilized with a smooth idle (this is a Roadmaster after all). Would an Edelbrock Pro-Flo EFI system be appropriate for this application?
I dont see engine bay clearance being a major issue; the car has a long bulging hood that used to hold a big straight 8.
I hope to drive this car 5000+ miles per year. Any advice or comments would be greatly appreciated.
Thanks!
Justin
Metairie, LA
Old 12-20-2003, 07:55 PM
First option might be a 455 Buick -
even with a stock sedan engine you
get tons of torque. You just have to
be careful with the front cover which
contains the oil pump - they often wear
out in the pump cavity, and the engine
has relatively poor oil flow passages
with the stock front cover.
Another great engine is a 472 or 500 Cad. Massive torque, you can run with
fairly high gears - you don't want to turn
a stock Caddy over about 4,000.
Either of those can be had fairly
reasonably with a little shopping and
are less weight than a big block Chev.
Other possibles are a 455 Olds or Pontiac - the Pontiac probably is the cheapest to warm up a little and doesn't have reliability problems in basically stock form. That engine isn't as heavy as a BBC either. Or, you could use a 428 or 421 Pontiac.
