Heres the answers to the 2 questions above. The solid green wire is the turn signals, the green/white is the park lights. Yes, the park light wire will light the bulb without the relay.
Here is a revised dia. Keep in mind, the relay will not create enough draw for the flasher to flash, you are going to need some resistors or an electronic flasher..... both can be found at superbrightled.com
| Rear Turn Signal Not Working With Lights ON | Craig legacy | Electrical | 1 | 09-02-2010 02:38 PM |
| Parking lights from Turn signal lights | 32chevy vett | Electrical | 7 | 03-30-2007 06:46 AM |
| If your driving in the left turn only lane, Do you signal? | alittle1 | Garage - Tools | 20 | 11-21-2004 06:56 PM |
| Brake light/turn signal lights wont work together | ChevyForever | Electrical | 1 | 10-04-2004 01:19 PM |
| How to convert to flashing hedlights instead of turn signal lights!! | willys36@aol.com | Electrical | 5 | 08-11-2004 07:16 PM |
