Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - drop
Thread: drop
Old 07-26-2005, 10:00 PM
Deuce Deuce is offline
BOTH.........
Dropped spindles and drop springs both work good. The dropped spindles do NOT affect the ride at all. Drop Springs, as a general rule, are shorter (but the same spring rate) lower the truck but the ride is diminished a little.
DO NOT use cut springs. For every 1 coil you remove, the spring rate goes up....
