drop - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2005, 08:41 PM
drop
What is the best way to drop a truck without sacraficing the feel of the ride. Should I go with drop spindles on the front or just drop springs. I will be able to afford airbags later. Any info would be nice.
Old 07-26-2005, 09:00 PM
BOTH.........
Dropped spindles and drop springs both work good. The dropped spindles do NOT affect the ride at all. Drop Springs, as a general rule, are shorter (but the same spring rate) lower the truck but the ride is diminished a little.
DO NOT use cut springs. For every 1 coil you remove, the spring rate goes up....
Drop springs for 65 Impala misterwaterfallin Suspension - Brakes - Steering 3 10-03-2008 05:47 PM
To drop or not to drop joeford Hotrodders' Lounge 3 05-11-2005 02:48 AM
body drop flamedfordbronco Body - Exterior 6 01-12-2004 06:17 PM
Drop Spindles black66 Suspension - Brakes - Steering 1 08-07-2003 04:32 PM
1 ton dually suspension drop slider in wa Suspension - Brakes - Steering 5 07-17-2003 09:32 AM
