drop axle help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2010, 10:52 AM
drop axle help
I am planning to use a forward sprung axle and spring assembly (after market unit off a friends '37) on a build of a '29 roadster. I realize this is an unusual and odd combination. The axle I have is tube design with 4 bar and uses a welded on perch mount instead of the original bone set up for the spring mount. The unit came to me from an IFS conversion and it was a driving functional assembly when removed. The frame I am using is also a left over from a previous build that received a new tube frame. It's a modified frame(somewhat reminiscent of a pinched 32) and there is plenty of room for a modified front cross member to accept the forward spring. The grill shell / hood arrangement also allows for the extra forward space so appearance is not an issue. Unfortunately I have limited experience with drop axles and application. I believe the only issue with using a forward mounted spring axle assembly on a 28 through 32 is space but would like other opinions before I start welding. The Idea of this build is to try and utilize 20 years of collected parts and while swapping for a traditional spring over axle is an option, unless there are some handling issues or other real world application problem I would like to use the forward sprung axle. Thoughts and comments related to the viability of this application or any associated driving concerns are greatly appreciated.
Old 05-02-2010, 12:08 PM
kleen56's Avatar
Not really clear what your trying to do by your explanation. I did a swap similar to what your talking about. It is possible to put it in, however final adjustments and setup can be tricky. The axle needs to be straight and true, steering linkage is a factor. I did everything possible and after I installed the axle and had everything looking good, I had a lot of bumpsteer, (car jumps into another lane for no reason). I had to shorten the draglink and steering box arm considerably. At the straight ahead position, the steering arm should be straight down and the draglink connecting to the steering arm needs to be hortizonal. I had a heck of time getting that adjusted. It definitely improved the bumpsteer and the alignment adjustment also made a difference. I understand why people install IFS front ends though. Just my 2 cents.
Old 05-02-2010, 05:34 PM
Thanks for the response, I guess I wrote a lot and really said very little. The actual question was aimed at using a spring forward assembly versus the normal spring over axle combination. I have seen very few 28 through 32's with that type axle arrangement. I assumed the combo was not desirable because of the space that set up requires. I was actually asking if a spring forward drop axle offers any negative performance issues on a light car versus the spring over. Your comments are helpful and appreciated. Over the last 20 years I have changed out a number of beam axles for IFS but never installed or ran a drop axle. The axle in question is actually a take out from a friends '37 that we converted to IFS several years ago.
Old 05-02-2010, 06:03 PM
kleen56's Avatar
I understand what your trying to accomplish. Give these guys a call or email them. They are sharp on this subject and will help. Especially prior to cranking up that welder.
http://www.rodfactory.com/NewFiles/28-31%20drop.html
Old 05-02-2010, 07:28 PM
Thanks for the link, I really appreciate the help.
Old 05-03-2010, 08:37 AM
Frisco's Avatar
Glad To Be Here
That mid '30's thru '48 stock style setup (spring in front of the axle) when used on a Model 'A' or a '32 looks odd. That's one reason it isn't done very often. If the front crossmember is not relocated, then the wheelbase will end up being shorter and the handling may be affected negatively. If a full fendered car, the view from the side will look very odd and the tires will probably rub the fenders. Moving the front crossmember to keep the wheelbase the same as original will solve handling and the odd appearance from the side.
It would be a lot simpler to just install an over the axle spring to that dropped axle. No crossmember changes would be required and the look will be correct.
Old 05-03-2010, 10:02 AM
Thanks for the perspective. The frame has been z'ed and the current cross member is just tacked in so moving it for corrected wheel base isn't an issue.
I have several axles in various condition from earlier IFS conversions but this one (the spring forward) is the most complete. Unfortunately it's also an odd axle in that it has all welded fixtures. The four link brackets are welded to the axle and the spring perch is also a welded bracket. I have no idea on the axles brand other than to say it was professionally welded (purpose built) and was under a '37 resto originally built in the late 70's or early 80's. I do have a separate 4 bar and bat wing set up, new spindles, hubs, tie rod and drag link assembly for a spring over. I am minus a good axle spring hangers and spring but the more I hear it would seem that my best bet may be to buy a lucky 7 or Bell axle and go with a more common spring over set up. Again thanks for taking the time to respond. I've not set up a beam axle before and want to make the best choice.
Drop Axle help 68RATVT Suspension - Brakes - Steering 6 11-09-2009 08:50 AM
Relocating rear axle Augusto Transmission - Rearend 6 09-09-2009 08:11 PM
Drop my camaro e6205m Suspension - Brakes - Steering 7 07-06-2007 01:46 PM
1940-48 Ford car axle drop teched Suspension - Brakes - Steering 6 10-10-2004 05:06 PM
Where to get a cheap drop axle for my model A teched Suspension - Brakes - Steering 4 09-24-2004 02:56 PM
