which drop for front? - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: 2" or 3" drop?
2 in drop 0 0%
3 in drop 4 100.00%
Voters: 4. You may not vote on this poll
Old 08-23-2003, 01:22 PM
mitmaks's Avatar
Last journal entry: Grille
hey guys, i need to lower front on my s10, after i've salvaged it from junk yard i replaced all damaged front suspension components and now front is higher, but i think its due to having stock coil springs, i thought about putting in lowering springs, but not sure what inch drop 1", 2" or 3"?? I think about 2" or 3" would be fine, right guys? heres attached pic how it looks like, but i am not sure if u can see difference from back vs front, but in person u can see big difference in heigh. Almost like i had V8 in it and now i put in I4 and front is just sitting up. Let me know guys what should I do, drop it 2", 3" or do something else, also i am on limited budget so i just decided to get lowering springs for now. thanks.
Old 08-23-2003, 01:35 PM
mitmaks's Avatar
heres picture.
Old 08-23-2003, 09:04 PM
hatetank's Avatar
i think 3" would look good. good luck
Old 08-24-2003, 08:16 PM
madhat's Avatar
wow, that does sit high...the flat rear tire doesnt help either...and as much as I'm not a big fan of converting trucks from utility duty, I think a 3" drop is your choice...that or raise the rear.
Old 08-24-2003, 10:19 PM
akm akm is offline
you are not too low with a 2''.
Old 08-26-2003, 10:20 AM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
I like the look of a real low truck. I would go with the 3" and even a 1" block in the rear. But then I would also go with a 2" drop spindle later on along with some more drop on the rear, but that's when the money comes. I'm going to be doing a 5/6 drop on my S10 after Christmas (when I get some money).
