Drop my camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2007, 05:19 PM
Drop my camaro
Hello,
I have a 67 camaro that was restored about 5 years ago. When they bilt the car they replaced the springs front and rear. It has the stock small block springs up front and and new multi leaf springs in the rear. I just put 17" Amaerican raceing rims on the car and I want to drop it around 2" in the front and 3 inches in the rear.
1st question
Can I drop the rear with removing the shortest spring in the spring pack. ( i believe it has 4 leafs). How much will that drop it? do the Drop blocks that are at Pep boys fit this car, the universal ones that fit light duty trucks and cars. I was considering removing the short spring and a 1-2" block.
2nd question
I probably will buy a set of drop springs but if i wer to cut the front springs how much do you have to cut in order to drop it 1-2 inches. 1 ful coil?
At this point i don't want to spend the $350 to buy a set of drop springs that probably won't give me the amount of lowering i want.
Currently the car has about 2" between the tire and the opening of the fenerwell in the front and about 4" in the back.
P.S. I am going for the Pro touring look.
thanks
Ron
Old 07-03-2007, 11:52 AM
Help Me lower my camaro
Is there anyone who can help me out with the above question. Any information would be appreciated.
Thanks
Ron
Old 07-03-2007, 12:04 PM
malc's Avatar
Living At The Speed Of Life
Try Year One Look in suspension.
Old 07-03-2007, 02:13 PM
Speedway has 2" dropped spindles for early Camaros for $240.00 and a disc brake kit for another $240.00.
Bob
Old 07-06-2007, 11:33 AM
Droped camaro
Sorry but i have been away from my computer. Thanks for the replies. I really was wondering about the rear suspension.
Thanks
Ron
Old 07-06-2007, 01:19 PM
I used 1" drop blocks on my T/A for the rear and it dropped it a bit more then an inch. I also did a no no with the coils and heated them and basically lost a little over an inch. It sounds like your car is to nice to be heating coils. I would put the 1" drops in the back and see how that looks if it's not low enough then take them back and get the 2" drop blocks. Spend the extra money on some dropped spindles or shorter coils. I am in no way recommending that you heat your coils. Which i doubt you would anyway. Thats my 2 cents. Good luck.
Mark.
Old 07-06-2007, 01:29 PM
Thanks for the reply Mark. Have you ever removed the shortest leaf in your rears suspension. How much do you think that would lower the car.
thanks
Ron
Old 07-06-2007, 01:46 PM
I have'nt removed any leafs. But i doubt it would lower it that much. But i really don't know for sure. Sorry.
Mark.
Can I make my 78 firebird into a Camaro? Suckingas Body - Exterior 9 06-28-2010 11:06 PM
4" drop pitman arm for 85 chevy 3/4 ton punk1c5040 Suspension - Brakes - Steering 1 01-01-2007 05:04 PM
Camaro Spindle Change PBR Suspension - Brakes - Steering 0 01-19-2003 03:12 PM
What was the best Camaro year? Jon Hotrodders' Lounge 34 11-29-2002 10:11 PM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 11:45 AM
