drop shock?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2007, 02:46 AM
drop shock??
i am dropping my 75 chevy truck. am using 3 in drop spindles and air bags up front. also 15 in by 7 in wheels. can i use stock length shocks or do i need drop shocks for this? the spindles wont affect this, only the bag. thanks
Old 10-25-2007, 07:58 PM
Art Deco's Avatar
The easy answer here is to ask what is the total suspension travel and what is the fully compressed length of the shock?
Just dont let the shock bottom out at full compression of the suspension. Consider fabbing a bump stop.
66 chev truck rear drop shock options? badriand Transmission - Rearend 0 07-17-2007 01:57 PM
Drop my camaro e6205m Suspension - Brakes - Steering 7 07-06-2007 01:46 PM
Rear Shock Placement, Angles ZipZ28 Suspension - Brakes - Steering 22 10-08-2005 01:52 PM
Should i use drop shock? Streetmaster Suspension - Brakes - Steering 2 09-08-2005 11:32 PM
Lever Shock is in the way! rwruther Suspension - Brakes - Steering 0 06-11-2004 02:20 PM
