Drop Spindle Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2004, 11:34 PM
black66's Avatar
www.airriderz.com
I have read most of the drop spindle/disc convertion topics. But I did not see the problem I am having.... Please take a look at this website and give me your thougts.....
Front End Problem
My car is a 66 Impala..... And I am at my wits end with these drop spindles....... Thanks.......
Old 05-27-2004, 01:03 PM
Pony's Avatar
Have you talked to the supplier about the problem?? From the ball joint to ball joint measurement it looks like it was intended for a shorter or softer spring. That could solve your hard ride and lack of adjustment problems. The other measurements could be necessary to keep the geometry correct during suspension travel. I've Not messed with dropped spindles so this is Only my guess. I've heard good and bad about dropped spindles. I looked real hard at them for my 53 ford sedan w/351C & C6, but the extra weight and power would have been too much for the old suspension/brakes. I used an 80 Chrysler torsion bar front k-member and rectangular tube front frame section. Got disk brakes and power steering to boot. Good luck and let us know how it turns out.
Old 05-27-2004, 01:47 PM
black66's Avatar
www.airriderz.com
Well I had talked with the drop spindle supplier yesterday. They where a little salty with me on the phone. Saying that the spindles where correct and I must have installed something wrong....... That was until I showed them the pictures..... Got love those digital cameras..... And you are correct about drop spindles. I too, have heard good and bad storys... Hopefully they will take care of this.....
Thanks a bunch.....
Dave
Old 05-27-2004, 08:04 PM
black66's Avatar
www.airriderz.com
McGauphy's Drop Spindles
Has anyone had any experience with drop spindles from a company called McGauphy's? If so, please share you experience..... Thanks......
Dave
Old 05-27-2004, 11:19 PM
black66's Avatar
www.airriderz.com
Here is a shot of a 65 Impala passenger side . And my 66. 65 has stock spindles. I have drop spindles. 65 is up in the air. My 66 is on the ground.....
Dave
Old 05-28-2004, 06:31 PM
pzatchok's Avatar
OddJob
From the link you provided I would say you got the wrong ones.
From what I understand drop spindles shouldn't change any geometry of the front end. All the mounting points should be the same as the factory ones. It should only be the axle shaft on the spindle that is moved upwards between to two.
Your springs shouldn't bend to the side like they do.
Old 05-28-2004, 07:30 PM
black66's Avatar
www.airriderz.com
I have a new pair of spindles on their way. Hopefully they will be correct one.......
Dave
Old 05-29-2004, 12:48 PM
Frisco's Avatar
Glad To Be Here
Dave
That sounds great. You might check those springs also. They appear to be too long for your application. Let us know of your progress. Good luck!
Old 05-29-2004, 02:56 PM
black66's Avatar
www.airriderz.com
spindles
Yeah I just purchased the new springs from Summit two weeks ago. The are Moog springs and I double checked the parts number. Before the Moog springs I had new McQuay Norris springs in. Same problem........ That is why I took the McQuay Norris springs back I had figured they where the wrong spring type/rate........
It almost seems if I had custom springs made with a two or three inch drop the spindles would then work out great.....
I will let you know as soon as I get the new spindles...... Thanks......
Dave
Almost forget. Has anyone had any experience with www.performancesuspension.com. I would like to find some other 65 - 67 Impala guys who have used McGauphy drop spindles for there impalas..... Thanks.....
Dave
Old 06-01-2004, 11:21 PM
black66's Avatar
www.airriderz.com
yeah baby.....!!!!
I called summit today and they had given me the heavy duty big block springs. So I said the heck with that and put in my old springs that where cut 1.5 coils. But I cut another .5 coil off each. So now the car has a really nice stance.
I checked the camber and the tires are right on the money. And best of all...... Rides great..... I still think there is an issue with the drop spindles, being that I had to use cut coils to run them.
But I am veryy happy with the ride. It is plush, but firm. And I think the Edelbrock IAS shocks up front really help keep the car in line. I can not wait to get the front end aligned. Should be like a whole new car to drive.......
Thanks everyone for the help.....
Dave
