Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drop spindles?
Thread: Drop spindles?
Old 04-12-2013, 09:21 PM
MARTINSR MARTINSR is offline
Look at it this way. When you alter the spring IN ANY WAY to,lower a,car you loose suspension travel,which will cause it to bottom out,giving you a rough ride at best and bending something at worst.
When you use a dropped spindle you raise the axle which lowers the car but you do not change the suspension or the amount of travel. It is by far the best way.
John Long
Very good point I didn't even think of.
