Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drop spindles?
Thread: Drop spindles?
  #22 (permalink)
Old 04-12-2013, 11:12 PM
MARTINSR MARTINSR is online now
One other thing. When you alter your springs you will absolutely have to have car aligned. With the spindles it will have little effect on alignment other than caster. The reason it effects caster is because as your front comes down the angle between your ball joints (king pin angle) diminishes.
Any change is corrected with one little shim.
