Drop spindles for 1979 el camino
Hi I just purchased a set of 1980's drop spindles for my 1979 el Camino. I've heard allot of things like you need 80's hubs, rotors, and bearings then I heard that I need the upper A arm and ball joint from a 1980's. If anyone can tell me what I need to put them on correctly or is a mechanic or professional.
Thanks '79 Camino |
Not sure if theres much difference between the 79 and 80's model elkys. From what i though they were the same as far as suspension. Although i do have 2" drop spindles on my 83 elky and nothing extra was needed. If you need any pics of the items i have just let me know and il send them to you. currently it is all disassembled for a frame off restoration so pics will be easy to get too.
sorry i cant help much but just let me know |
re: Drop spindles for 1979 el camino
I have a 79 Lemans and was told that 79 e- body GM cars were different than the 80’s as well but no one could tell me how. I need a left side spindles so if you do the conversion I would be interested in buying them or at least knowing what I would have to change on mine if I wanted to go to dropped spindles.
The front end parts (ball joints, tie rod ends, control arm bushings) are all the same for 78-88 G-body cars (and trucks). The spindles should bolt on with no problems. The difference is the rotors and wheel bearings. You'll need the later model parts.
Drop Spindles
Thanks Joe, Sorry I meant G-bodies. As I said I talked to a few people about it (guy at the salvage yard and at the dealer) and all they could tell me is they were different. I was suppressed to find I could still buy new about 350.00. But if that is it then maybe I will consider the dropped ones.
| Early Ford Spindles fitting early Ford axles | pasadenahotrod | Suspension - Brakes - Steering | 3 | 08-14-2012 07:20 PM |
| 79' El Camino Drop Spindles? | '79 camino | Suspension - Brakes - Steering | 3 | 02-02-2008 03:03 PM |
| What vehicle to buy for swapping parts into el camino | 1970Chevy | General Rodding Tech | 4 | 09-28-2007 07:31 AM |
| Want El Camino 60's-70's project. | sixties | Hotrodding Basics | 2 | 01-11-2006 07:34 PM |
| el camino rear end ?? | mac95 | Transmission - Rearend | 3 | 01-01-2003 01:26 PM |
