Drop spindles? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-12-2013, 09:34 PM
This was my brothers 59 Chevy wagon he had in the early seventies with raise spindles. It was a foot over stock!
It was a super nice car (only about 13 years old remember) that our dad took in as a trade in for only $750. It was exactly as seen but had the same 6" wide Americans in back. Those 10 inch wide Chrome wheels, they were on a number of cars and are on his truck (our fathers 55 F-100) today. He had the offset changed so they are tucked in.
  #17 (permalink)
Originally Posted by fastal_12147 View Post
if it's as rough as you're saying i don't envy you
To be honest I just sold an 85 Camino with cut front coils. It had good soft suspension bumpers and wasn't terrible but the spindles are by far better. There are thousands of cars running around with cut coils and their drivers are happy. After all they lowered theirs for free.
John
  #18 (permalink)
Old 04-12-2013, 09:40 PM
Yeah, it isn't hack or anything like that, if you want to give it a go, pull the springs out cut a few coils off them and put them back in. The bad thing is you really are guessing how much it's going to go. Don't think if you cut 2" of the height of the spring it's going to drop 2". You change the spring rate when you cut them so it's a bit of a guess. You could also go the heating route. Put some blocks under the car at a little higher than the height you want and heat the springs with a torch until it sags down to the blocks then let it cool a good long time. Now this is a bit hack, but it's been done for years. Cutting them of course is way better, just don't go too far because then geometry gets all goofed up. But just a little lowering, a tasteful lowering, it isn't that big of a deal.
  #19 (permalink)
I'll take the truck thanks. Back in the day,we used to send axles Moredrop to get them reforged and dropped. The natural result or reforging them is that it narrows the axle slightly allowing for wider wheels. Last I heard they are still in business but it costs more to have an axle dropped than it does to buy a new one.
  #20 (permalink)
Old 04-12-2013, 09:50 PM
One other thing. When you alter your springs you will absolutely have to have car aligned. With the spindles it will have little effect on alignment other than caster. The reason it effects caster is because as your front comes down the angle between your ball joints (king pin angle) diminishes.
  #21 (permalink)
Old 04-12-2013, 10:10 PM
If I am not mistaken they are out of business. They quality had dropped a LOT over the years. Back "in the day" they did a beautiful job with it looking like it hadn't even been modified. But when I went by there in the seventies the friggin axle looked like pulled taffy, it was a HORRIBLE job. My dad managed a used car lot just down the street and you drove right by Mor-drop to get on the freeway to come home. But honestly, I hear horror stories about the king pin bosses being all distorted, they turned into an out and out hack shop.
The truck by the way is very nice. Our dad bought it in 66, brought home a 58 Buick trade in and a mechanic from the Buick dealer where he worked and the guy swapped in the 364. It was a hack job with the crossmember cut out. We both drove it to school. The frame was replaced and I now have it along with the original bed as my trailer. But this truck is very nice, the only mistake my brother regrets is the Cordova front suspension, he HATES it. But all in all it runs and drives nice.
  #22 (permalink)
Old 04-12-2013, 10:12 PM
Any change is corrected with one little shim.
  #23 (permalink)
Old 04-12-2013, 10:14 PM
LOL You just have to pay the guy to know which one and where.
  #24 (permalink)
Old 04-16-2013, 05:54 PM
57halfton's Avatar
Brian , The extended spindals in the 59 Chevy wagon brings back good memorys for me. In the early 70's I had a 65 Olds 442 that had 6 inch extended spindals in front and Ford station wagon leaf springs in the rear, The Olds road great and handled good too, all the suspension work was done by Al's automotive in South San Francisco. I sold it in 74, sure wish I knew where it is now.
Gene
  #25 (permalink)
Old 04-16-2013, 10:57 PM
Gene, I think that may be the place that did my brothers 59! I am going to fire him an email right now. That name rings a bell.
  #26 (permalink)
Old 04-18-2013, 08:59 PM
One caution when installing dropped spindles. The ground clearance under the front of the car will be reduced by the amount of the spindle drop. If you have 4 inches of clearance and put in 1 inch drop spindles, your ground clearance will be reduced to 3 inches.
The approach to avoid this is to "Z" the frame behind the front wheels. This allows the body and sheet metal to drop while maintaining the front ground clearance, but the engine moves up closer to the underneath of the hood.
John
Best drop spindles Mutt's37Buick Suspension - Brakes - Steering 2 02-06-2012 08:22 AM
drop spindles caletcb Hotrodding Basics 3 12-09-2009 04:02 PM
drop spindles bobrefill Suspension - Brakes - Steering 1 10-31-2004 05:46 AM
Drop Spindles black66 Suspension - Brakes - Steering 1 08-07-2003 04:32 PM
drop spindles madhat Suspension - Brakes - Steering 2 04-27-2003 07:44 PM
