drop spindles - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2005, 08:11 PM
drop spindles
hi there i am wondering if anyone knows if there are drop spindles for a 1975 ford courier. I mounted a 1923 Ford TT C-cab on a courier frame and cut 2 coils from the front suspension but still would like to get another 2 inches. Inclosed is a picture. Thanks for any input.
ID:	7218   Click image for larger version
Old 10-07-2005, 10:59 PM
WHY ?
Any lower will cause even less clearance.....
Old 10-09-2005, 02:42 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You defintiely need 4 inch dropped spindles.... those a-arms are at a horrible angle.
My guess is that you will have to change to an entirely different front end and re-engineer the whole thing.
F-100 drop spindles BAD JONNY Suspension - Brakes - Steering 2 03-04-2005 10:34 PM
drop spindles or lowering springs Echofive Suspension - Brakes - Steering 7 04-28-2004 07:01 AM
Drop Spindles black66 Suspension - Brakes - Steering 1 08-07-2003 05:32 PM
67-72 drop spindles chevyman17 Suspension - Brakes - Steering 2 05-01-2003 06:40 AM
Should I use drop spindles? 57Chevyman Suspension - Brakes - Steering 6 12-12-2001 11:38 AM
