Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - drop spindles
Thread: drop spindles
Old 12-08-2006, 07:31 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
It seems to me that the car will sit about 5/16 lower with the 16's and the stock spindles.
A 225 60-14 is 24.63 tall, while a 205 50- 16 is 24" tall.
Here is the spiffy chart where I found that info.
http://victorylibrary.com/mopar/car-tire.htm
Follow the directions at the top and you can calculate any size tire on any size rim.
Look at real specs of the actual tires you are going to run, as the measurements vary a little. Keep in mind that not all tires come in all sizes and some of those sizes in the chart may not exist at all. (don't get confused by the number seeming large for the sidewall height. It has already been multiplied by 2. )
Hope this helps, mikey
BE different....ACT normal.
