-   -   Drop of water in the base (http://www.hotrodders.com/forum/drop-water-base-74934.html)
Scode68 11-28-2005 12:49 PM
I just sprayed some Nason Ful-Thane and I got a water drop on the base coat. After thinking about it the only thing it could have come from was the outlet on the respirator. How should I go about getting this out? Tackle it like any other junk in the paint? Sand and reshoot the area or do I have to do the whole panel? It fell after the first coat flashed and I was applying the second coat.
jcclark 11-28-2005 01:05 PM
Oh yea, I done that.
Just wipe it off gently, lightly scuff and base another coat on it.
Shouldn't be a problem, as long as it's dry.
adtkart 11-29-2005 05:08 AM
Scode.... I would check the air lines for water. A few years ago, I had problems with water in my lines. They didn't appear to be leaking air, but I got water out of the fitting at the gun. I have talked to others that had the same thing happen to them.
To repair mine, I did just wipe it off lightly after a few minutes and shoot another coat over it, before clearing. No problems with the finished product.
Aaron
jcclark 11-29-2005 06:06 AM
When I take my respirator off between coats
(after leaving the paint area) I wipe out my
respirator because it does build up with condensation
and then leak out when I'm leaning over.
I have had that happen a lot when it's hot.
Bee4Me 11-29-2005 07:57 AM
That AND,
Your GLOVES if you use them.
One of the WORST places for water as they make your hands sweat like crazy.
shine 11-29-2005 02:23 PM
i keep Kleenex in the booth. i twist one to a point and keep it ready. lot of sweating here in central texas. you can suck up a couple drops and go on.
you can put a small piece in your mask.
Scode68 11-29-2005 03:46 PM
It definitely came from the mask. The drop shrunk up a bit (water dried) but itís still noticeable.
Paintguy 11-29-2005 04:58 PM
Be thankful you're not using water-borne base like I do.
A simple bead of sweat can really ruin your day :(
