Drop of water in the base - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2005, 11:49 AM
Scode68's Avatar
Ed S.
I just sprayed some Nason Ful-Thane and I got a water drop on the base coat. After thinking about it the only thing it could have come from was the outlet on the respirator. How should I go about getting this out? Tackle it like any other junk in the paint? Sand and reshoot the area or do I have to do the whole panel? It fell after the first coat flashed and I was applying the second coat.
Old 11-28-2005, 12:05 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Oh yea, I done that.
Just wipe it off gently, lightly scuff and base another coat on it.
Shouldn't be a problem, as long as it's dry.
Old 11-29-2005, 04:08 AM
adtkart@aol.com
Scode.... I would check the air lines for water. A few years ago, I had problems with water in my lines. They didn't appear to be leaking air, but I got water out of the fitting at the gun. I have talked to others that had the same thing happen to them.
To repair mine, I did just wipe it off lightly after a few minutes and shoot another coat over it, before clearing. No problems with the finished product.
Aaron
Old 11-29-2005, 05:06 AM
jcclark's Avatar
The Penny Pincher
When I take my respirator off between coats
(after leaving the paint area) I wipe out my
respirator because it does build up with condensation
and then leak out when I'm leaning over.
I have had that happen a lot when it's hot.
Old 11-29-2005, 06:57 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
That AND,
Your GLOVES if you use them.
One of the WORST places for water as they make your hands sweat like crazy.
Old 11-29-2005, 01:23 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
i keep Kleenex in the booth. i twist one to a point and keep it ready. lot of sweating here in central texas. you can suck up a couple drops and go on.
you can put a small piece in your mask.
Old 11-29-2005, 02:46 PM
Scode68's Avatar
Ed S.
It definitely came from the mask. The drop shrunk up a bit (water dried) but itís still noticeable.
Old 11-29-2005, 03:58 PM
Be thankful you're not using water-borne base like I do.
A simple bead of sweat can really ruin your day
Water in Engine billg_69gmc Engine 1 08-24-2004 09:14 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Timing/Water Injection Mertz Engine 7 08-20-2002 07:31 AM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
