droped rear end!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2005, 07:00 PM
nicowarrenrogers's Avatar
Today i went to go put the car up on all fours (the rear has been up four a couple of months) after i had finished it dropped back down! Front still had tires on it but the back didn't So i freaked out to get the rear back up and i noticed one of the stands had broken and shifted over so only one side of the rear hit the ground. Is there a way to determine if the rear end is damaged??? It is a Ford 8.8 in a 69 mustang.
Old 04-19-2005, 07:25 PM
Max Keith's Avatar
dropped rear end
Jack the car back up, make sure you have it well blocked, then inspect the rear end. If there is any damage, most likely it will be to the brake on the corner that hit the ground.
Old 04-20-2005, 06:08 PM
How am I to inspect it??? the drum being tighter, bent in drum, tire woble?
Old 04-20-2005, 10:34 PM
Max Keith's Avatar
inspection
Look for chipped spots on the drum, cracks, spin the drum and see if it looks like it might be out of round.
Check your brake lines on the axle.
Check your shocks and springs and mounts for both.
Old 04-20-2005, 11:01 PM
I spun the wheel and it has like bumpy spots on it. It will go and than get hard to spin and spin freely it bumps about every 1/4 spin. Also when i dropped it back down with tires the wheel seemed kind of crooked.
Old 04-21-2005, 07:47 AM
Max Keith's Avatar
Inspection
Sounds like at the minimum, you have warped a brake drum.
Old 04-21-2005, 06:06 PM
Is there a posibility that i bent the frame or driveshaft?
Old 04-21-2005, 07:27 PM
Max Keith's Avatar
Dropped axle
IN all probabilities, unless your car landed on a point on the frame, which other than the rear frame kick, its unlikely. If it had landed on the frame, there would be body damage at that point, since the body does hang down below the frame, so it would be very evident. If it landed on the hub, the springs would have taken the impact and would have deleted the chance of frame damage, however, the sheet metal of the body isnt nearly so strong, and you could still have a crushed rocker panel or rear panel. Look over your lower body edges on the side that fell.
Old 04-21-2005, 08:19 PM
The reason for me asking was because the door on the side that hit lines up at the top of the door but at the bottom the rear panel is about 1 inch inward. Is this just bad door alignment?? Because the doors werent on when i got the car.
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
