As stated a four bar will work smoother, what wasn't said is that you can use a hairpin setup with an I-beam axle but you'll eventually break a tube axle with a hairpin because they won't twist like the I-beam.
[ March 30, 2003: Message edited by: woodz428 ]</p> |
Also not yet stated is that the caster (the degree of angle) changes a lot less with a 4 Bar than with the hairpin. Most rod builders use the 5-7 degrees figure to set up the 4 Bar front ends. The 4 Bar setup is the most correct setup you can use with a straight axle (engineering wise). The 4 Bar is a parallelogram. The hairpin is considered better looking (by some). If you have fenders.....the 4 Bar should be strongly considered. No fenders...... a hairpin setup does look best. Also what has been said about the tube/I beam usage is TRUE. A tube will break with split wishbones/hairpins <img src="graemlins/sweat.gif" border="0" alt="[sweat]" /> .
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
