-   -   dropped axle (http://www.hotrodders.com/forum/dropped-axle-206020.html)
65shelby 09-23-2011 08:09 PM
dropped axle
Any recommendations on a drop axle complete kit supplier? Who makes the best? Thank you
35terraplane 09-23-2011 10:05 PM
Dropped axle
Super Bell makes them, I have used one on a 40, but I won't get into which one is best. :nono: :nono: Good way to get people po at each other. :sweat: :rolleyes: :pain:
Bob
OneMoreTime 09-23-2011 11:07 PM
speedway carries the complete units..all the pieces that you need..
Sam
user151 09-25-2011 12:37 PM
Chassis Engineering (West Branch, Iowa) has forged dropped axles, forged spindles, and all the other parts you need. They also have sets (kits?).
65shelby 09-25-2011 05:20 PM
drop axle
thank you 151, I will check them out. i was just hoping to hear others opinions on what works good and what they are happy with as well. I-beam vs tube, hairpins vs 4 link and bones, spring over vs spring behind, mono leaf vs multi etc.....thanks again
Deuce 09-25-2011 09:57 PM
I always use the TCI axle and 4 bar pieces.
http://www.hotrodders.com/journal_ph...1431429641.jpg
http://www.hotrodders.com/journal_ph...1431429642.jpg
They sit low and handle well ...
http://www.hotrodders.com/journal_ph...2316220811.jpg
Some years ago, Rod & Custom magazine had a article about a road test. It was Gray Baskerville's 32 roadster Versus Jerry Kugel's Jaguar IFS/IRS 32 roadster. Baskerville's roadster beat the Kugel roadster in a few areas. Overall the test was considered a draw. A well set up 4 bar dropped axle car handles very well.
http://image.rodandcustommagazine.co...erry_kugel.jpg
BOTH ... the 32 roadsters are well known in the Hot Rod world ... and BOTH are in the Los Angeles area.
Mojo56 09-25-2011 11:48 PM
I like Henry's original axles...they look the best IMHO and are genuine forged from Ford's own recipe steel.
Chassis engineering would be my second choice. I have had two and they are nice units but not as pretty as the Ford units.
Depending on what style of car you are building you can use a split wishbone, hairpin or four bar.... your choice but split bones and hair pins look 'right' on an open wheel car...again IMHO.
I prefer P&J or SoCal hairpins and batwings.
user151 09-26-2011 05:27 AM
It is said that if you use a tube axle, use four bars (not hairpins or bones).
Since a forged I beam is more flexible, you can use any locating system.
