Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #46
Old 12-21-2005, 10:40 AM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
re: Dropped Axle on a 37 ford can i keep the original wishbone?
Originally Posted by cliff tate
my error i ment i put a 302 into a 1947 ford 2dr car useing a adaptor to the 47 transmittion., eventuallymodified the case and inst 56 gears then the ujoints broke,those old trans ar very frail i have a 47 truck with the original type flathead and can break the trany if not carfull, cliff tate
I knew it was in error in communication....not a fabrication......like some of the ...tales... that are printed here...
Originally Posted by 37ford4dr
Smaller engine
The smaller engines make less torque and as a general rule like the RPMs better. I have a friend with a ZZ4 350 crate engine ( 355 HP ) in his 40 with original driveline and he has has no problems either. But he is not 18 either........ I have found the axle keys to be the weak link.......sort of like a fuse in a electrical circuit.
Old 12-21-2005, 11:08 AM
37ford4dr 37ford4dr is offline
bobs77vet
Originally Posted by Deuce
I
thanks, I'm way on the other side of 18..........although with those steep rear end gears and those tall skinny tires (and probalby not a posi rear end right?) i bet you could smoke those tires all day long,or at least one of them....
Old 12-21-2005, 11:28 AM
 Deuce's barnstar
UNTIL something broke........most likely one of the axle keys.....
Old 12-21-2005, 08:48 PM
bobs77vet
If original, the ratio will be stamped on the rear end housing. On the banjo section.......look on the passenger side.......at about 2 oclock.....it should be stamped there.
ok looked tonight and couldn't see anything the banjo section is the middle part that is connected to the torque tube and resembles a "banjo" and it has the filler hole plug in it? and the two axle shaft housings attach to the "banjo"? how big will the stamping be? this stamping will be on the passenger side ,and the engine side of the "banjo" by the torque tube at 2:00?
Old 12-21-2005, 09:24 PM
 Deuce's barnstar
Yes.......
The numbers should on the engine side........passenger side at 2 o'clock....
The numbers are 3/8 maybe......and not real deep.
IMHO..............I would go with a Chassis Engineering rear end kit. Buy a front end kit ...and proceed with late model stuff. My old black 40 was a lot of FUN....but it was not a maintenance free ride. The brakes are not self adjusting. The manual steering was old and had to be adjusted. The clutch and clutch linkage had to be adjusted. NO A/C... I enjoyed it.....But my wife did not like driving it.
AND I have a maintenance free DEUCE....to really ride in.
IF something happened......( which never did ) it was rollback truck time. Or go home and get the trailer.....because you could not find anything for parts to fix it on the road......other than SBC engine stuff......and with a fresh SBC....I NEVER have a problem....
You need to decide which way is BEST for you......before you ever turn the first bolt....
Old 12-22-2005, 07:39 AM
bobs77vet
great advice and i'm still deliberating....i figure i will take care of some of the floor board rust this winter and get to know the car real well and then start coming up with a plan, partly based on what is the easiset for me to source with used parts such as the rear end. i don't mind buying a new front end setup but this is going to be a driver....i'm finished with show cars i want people to be able to get in the car and enjoy with out worrying about scratching paint....been there done that ....but not again...
Back to top
This discussion has been added to the Suspension - Brakes - Steering Discussions category of the Hotrodders Knowledge Base.
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Dropped Axle on a 37 ford can i keep the original wishbone?"
dropped axle on 64ss chevelle hot64ss Introduce Yourself 1 12-05-2004 09:01 PM
Dropped Axle adtkart General Rodding Tech 5 12-27-2003 07:45 PM
determining right dropped axle adtkart Suspension - Brakes - Steering 4 08-12-2003 05:48 PM
9" ford rearend 37 ford melbishop Transmission - Rearend 3 12-09-2001 09:15 AM
40 Ford Dash in a 37 Ford?? Carnut39 Interior 1 12-05-2001 05:51 PM
