Dropped front axle questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2008, 01:43 PM
Hi All,
I am building a 61 Willys Wagon into a street rod. It started out as 4x4 but I am converting to 2wd. I am looking for front end options and due to the open nature of the Willys front fenders I do not want to use a MII. So in looking for a dropped straight axle I came across Speedwaymotors. any feedback on using this setup on the Willys?
SpeedWayMotors Semi-elliptical drop axle
Also any idea on what kind of height I am looking at from axle center line to bottom of frame using this setup?
Mike
Old 01-17-2008, 08:55 PM
31 five window
Last journal entry: grill and rear end
This set up should work very well but I can't give any figures and it will vary depending on engine and tranny weight.A friend off mine has this set up on his willys truck with a SBC and it sits nice. Not too low not too high.
Old 01-18-2008, 07:51 AM
Thanks for the reply. I am also going with a 350/350 combo. Not looking for anything too low so hopefully this will be what I am looking for.
Mike
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
'47-'54 front axle flip!? suedespade Suspension - Brakes - Steering 3 04-13-2007 09:00 PM
Model T front axle ? gahi Suspension - Brakes - Steering 6 11-16-2004 09:48 PM
83 bronco front axle clicking Jared Transmission - Rearend 2 02-11-2004 11:10 PM
34 ford truck front axle ideas and questions lilred34truck Suspension - Brakes - Steering 1 10-30-2002 06:20 PM
