dropped front leaf question.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2007, 09:43 PM
Prof. T. Soggmeyer's Avatar
Plan B
I am putting in a 3" dropped front leaf setup(replaces stock ones) on my 49 3100. And I can't get the rear eye bushing to line up with the hanger enough to get the bolt through. Is there something I missed (easy now). Can I grind just a tiny bit up in the hanger?It is all cleaned out and the leaf still needs to go up a fat 16th to get the bolt in. Any tips and I owe ya a beer or what ever ya fancy.
Brad....
Old 09-18-2007, 11:37 PM
Chopt 48's Avatar
The diameter of the eye of the spring must be larger than the original spring .
It probably won't hurt to grind a bit off for clearance but I don't think I would get carried away. If the spring has a reversed eye you may need a bit of clearance at the front side for that.
Old 09-19-2007, 06:25 AM
Plan B
It does not have a reversed eye, and I shouldn't have to grind too much.It'll be one of those awkward grind positions though. No biggy. Thanks chopped for the 2nd opinion, I didn't want to do something stupid.
Brad....
front end question jbowman Suspension - Brakes - Steering 8 11-29-2007 08:48 AM
Mustang II Front with S10 Dropped Spindles sodas38 Suspension - Brakes - Steering 4 01-03-2007 12:08 PM
Front Air Bags and Leaf Springs BillVV Suspension - Brakes - Steering 1 06-16-2006 07:07 PM
T-Bucket owners - Front suspension question cucumber1949 Suspension - Brakes - Steering 3 01-02-2006 06:17 PM
Front pump question Jmark Transmission - Rearend 1 05-12-2004 09:46 PM
