dropped i beams - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2007, 05:30 PM
dropped i beams
im currently working on a 1966 f 100 truck. i was wondering if the only way i could drop the front end would be drop i beams ?
Old 02-18-2007, 05:54 PM
dropped I beams
aside from clipping the frame and changing the complete front end,the dropped I beams are the only way you will be able to lower the truck and maintain your correct front end geometry. any change in heigth (up or down) drasticly changes camber on those twin I beam front ends.
Old 02-18-2007, 07:34 PM
cboy's Avatar
Last journal entry: Finished
Originally Posted by 39 chev
...any change in heigth (up or down) drasticly changes camber on those twin I beam front ends.
True, unless you raise the pivot point as well as the "spring" point of the I beam. Not possible on all years/models but might be on yours. You'd have to do some measuring. You also have to insure the beam will have enough travel clearance from all frame members. The other negative is that at a maximum you'd probably only get about 1" to 2 " drop.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 03-23-2007, 09:07 PM
66 Truck-ford
CHECK OUT CLASSIC TRUCKS MARCH$APRIL ISSUES--INSTALLING MUST2 AND COLUMN--good article on installing front end-crossmember-and must2 still cheaper than dropped I-beames-ride a lot better-and handle good
Dropped Spindles Chevy535 Suspension - Brakes - Steering 1 08-08-2006 04:23 PM
Mustang II dropped spindles vs. std. GS Guy Suspension - Brakes - Steering 4 06-17-2005 11:49 AM
Twin I Beams SMF Speed&Custom Suspension - Brakes - Steering 3 06-09-2005 02:18 PM
Bumpsteer with dropped springs? Led Sled Suspension - Brakes - Steering 2 09-08-2004 07:31 AM
Buick Dropped Spindles Short Bed Shorty Suspension - Brakes - Steering 0 04-23-2003 12:08 PM
