Dropped/Lifted Spindles For Diesels? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2003, 12:30 AM
TheGreatWhay's Avatar
Post Dropped/Lifted Spindles For Diesels?
Does anyone know if the Spindles for an 85 Suburban are the same between the 1/2 ton and the 3/4 ton? Here is my dilema. I am wanting to lift preferrably, but lower as another option this Suburban. Right now it is considered a 3/4 ton with a 6.2L Diesel. I am hoping I can put a Ford 460 in place which would change weight and the issues that make lifting or lowering a Diesel Suburban no longer relevant..(At least that I know of) In other words, no one makes anything for lowering or lifting 3/4 ton Suburbans with Diesel engines.
All help is appreciated in advance.
J
Old 10-28-2003, 12:52 AM
BigBlockBabe's Avatar
Missing You
Head over to www.fullsizechevy.com or www.customtruckshowcase. I'm pretty sure those guys would know.
In the mean time, I'm moving this to the suspension forum....
Old 10-28-2003, 10:41 PM
Thanks BBB...Hopefully some answers will come to pass.
Old 11-19-2003, 12:23 AM
jalopy45's Avatar
Cool
Ignore the diesel label. You can use 1/2 ton spindles and ball joints and raise or lower to you hearts content. The same with 1 ton spindles. The 1/2 ton setup will convert you to 5 bolt wheels and the 1 ton will keep your 8 bolt wheels. If you want to raise the sub give a call to an off road shop and ask about their pre-runner suspensions.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 11-19-2003, 12:44 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
The ! ton spindle is different from a 1/2 ton also the ball joints are different.
I've converted several 3/4 tons to 1 ton dually, by just changing the spindles and rear end.
I used bell dropped spindles on my 3/4 ton, and they were different part #s than a 1/2 ton, I also cut one coil off.
Troy
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
