dropped spindle on straight axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2009, 03:38 PM
Last journal entry: frame build
Dropping a set of pontiac spindles for use on a 47 ford straight axle. To get what I want, the spindle centerline will come out at the upper kingpin boss. What effect will this have on steering?
Old 05-06-2009, 08:58 AM
Frisco's Avatar
Glad To Be Here
Assuming that the Pontiac spindles can be adapted to the early Ford straight axle, the built in camber of the spindles may be different than what is required for the built in camber of the Ford straight axle. If this is the case the axle can be bent to achieve the correct camber. Any good front end shop can do this. You may have to go to a shop that specializes in trucks.
The spindle centerline location should not alter the steering. The caster, camber and toe-in will all effect the steering
Old 05-06-2009, 10:07 AM
powerrodsmike's Avatar
Wiki Edits: 161
That's a new one on me, but that's what hotrodding's all about
If you move the axle up on the spindle it might change your scrub radius a little, which probably won't matter much since you will be probably be running shorter and wider than stock tires anyway.
It may put a little more stress on the upper kingpin bushing , but I wouldn't worry about it.
Pictures..we want pictures
Later, mikey
BE different....ACT normal.
Old 05-06-2009, 12:10 PM
Camber works out to 1 dg + as installed which I think is good.
Scrub radius at 7/8" out.
Pics forthcoming soon as we get a little further along.
Old 05-26-2009, 09:05 PM
Pics are up in my journal. Comments?
Old 05-27-2009, 09:43 AM
Frisco's Avatar
Glad To Be Here
Nice work and an interesting adaptation.
I am a retired Toolmaker and can appreciate the thought and work involved in this project. There are not many folks that would have even attempted this.
Old 05-27-2009, 10:02 AM
Wiki Edits: 161
It is really cool to see how a guy can come up with solutions to fabrication challenges using the tools he has...
VERY resourceful and creative application of your skills and materials. Very well thought out as well.
You are going to have folks saying "what the hell is that spindle?", for years....It'll be fun for you to watch them try to guess what you did.. hahahahahahah
Hotrodding at it's finest.
Later, mikey
front straight axle on 32 ford model b truck BonnevilleBrat Suspension - Brakes - Steering 6 01-29-2009 12:00 AM
Welding spring pads on straight axle heyjude076 Suspension - Brakes - Steering 2 06-25-2008 09:07 AM
determining right dropped axle adtkart Suspension - Brakes - Steering 4 08-12-2003 06:48 PM
straight axle falcon kalowry Suspension - Brakes - Steering 13 01-04-2003 04:26 PM
1938 chev - straight axle front end WILLARD(SONNY)STOTLER Suspension - Brakes - Steering 4 12-30-2001 04:26 PM
