dropped tiny aluminum bolt into oil drain pan... - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2012, 10:56 AM
mrdreex's Avatar
I dropped a tiny socket-head allen bolt to my electric water pump while taking it off of my engine, straight into the oil drainage pan I put underneath the car when changing the oil, and it's full. Magnets don't work on aluminum, so, what is the best way to go about fishing that bugger out without getting hands deep into the oily muck that is in the drain pan?
Old 09-26-2012, 11:48 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Nitrile gloves ...
Old 09-26-2012, 12:33 PM
Steal a fine mesh strainer from the kitchen...
Old 09-26-2012, 01:51 PM
delawarebill's Avatar
bolt dropings
if u still have the pump off and u can get a really small extension type magnet down into it.. use another mag on the bottom of pan to move it to a good location. pull the pan mag straight away and stick in the ext mag in the same location..
Old 09-26-2012, 03:02 PM
Irelands child's Avatar
Time to get down and dirty, it washes off, or use the suggested nitrile (or latex) gloves - or just go get another bolt and forget about the one you dropped (howinhel can there be that much crud in an oil drain pan - mine could be used to cook supper after I've used then cleaned it)
Irelands child
Old 09-26-2012, 06:14 PM
tnovot's Avatar
If you don't have one around the house, go to a pet store or maybe even Walmart and buy one of those little mini dip nets used to remove fish etc from fish tanks.
You could even make one from a wire coat hanger and an old nylon stocking or cheese cloth.
Or, get a slotted spoon from the kitchen.
Tery
Old 09-27-2012, 10:18 AM
mrdreex's Avatar
Thanks guys, I like the strainer idea, bought one, but ultimately ended up going oil diving with some nitrite gloves...worked perfectly, and got the bolt out successfully and oily.
Old 09-27-2012, 10:44 AM
Funny story
When I used to work at the plating shop; one of the fun gags was to send the new plater's assistant to the Maintenance shop (next to my office) and ask the grumpiest guy (Ralph) for an Aluminum Magnet to fish some parts out of the etch tank. "make sure he gives you an aluminum magnet, these are expensive parts in the etching solution, they're turning into mush" Ralph gives the guy a bar magnet, guy goes back to the line "Idiot, look this is a STEEL magnet, it won't stick to aluminum...see GO BACK NOW" At some point I stopped wondering what they teach in 2nd grade science...
The other gag was tackwelding people's locker doors shut.
Old 09-27-2012, 01:03 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Charge up a condenser and toss it to someone w/wet hands.
Bet a guy he can't put a lit match out by putting it under an upside down dixie cup. That you spiked w/acetylene.
Old 09-27-2012, 01:45 PM
You are a cruel mo-fo...love it LOL
Old 09-27-2012, 06:46 PM
66GMC's Avatar
Send a noob for a stryrofoam cup full of lacquer thinner.
Old 09-27-2012, 06:49 PM
66GMC's Avatar
Oh man ... do you have a death wish?
Old 09-27-2012, 07:26 PM
RWENUTS's Avatar
SEnd a noob to the warehouse for a skyhook, an electric to air adaptor or some rubber rod.
How I fixed my stripped oil pan drain hole Argess General Rodding Tech 13 07-19-2011 09:16 AM
Will oil pan seal with one broken oil pan bolt? Dougie Engine 2 03-10-2011 08:29 PM
Cast Aluminum Oil Pan 123pugsy Engine 9 07-16-2009 03:56 AM
Aluminum oil pan western star Engine 11 11-29-2003 08:03 PM
Aluminum Oil Pan western star Engine 7 10-24-2003 09:44 AM
