Droppin' a BURB?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2003, 10:24 PM
Post Droppin' a BURB??
My question is simple. has anyone out there droped a straight front axle chevy truck (a '53 burb to be exact) by simply flipping the axle to the top of the leafs instead of leaving it on the bottom?? after looking the front end of my burb over, I have determined it should be fairly simple. part of the steering arm (on the outside of the frame) will need to be shortened, the frame will need to be 'c'notched (for bump stop clearance), and a plate for the new u bolts fabbed. not all that much work, and approximately a six inch drop is the result!!
if anyone out there has seen this done....done it...or even heard of someone who has done it, please respond and tell me if it is going to be a functioning deal. or if i need to just leave it alone and mustang II the front. fyi....i'm not subframeing the truck!!! no camaro or any other gm clip!!. i want it to remain as stock as possible. its an old school hot rod, not a 'bagged' billet cruiser. not that there's anything wrong with that. THANKS VERY MUCH!! <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
Old 05-09-2003, 03:35 AM
Post
You should measure for all the necessary wheel clearances for suspension travel and wheel turning and shock travel. I have a 37 Plymouth that had that trick done to it and it seemed to work fine. I replaced it with an IFS because I did not care for the stiff and truck-like ride it gave. I would suggest that you take as many dimensions as possible of the present setup and the calculate the altered setup before cranking on anything. Good Luck!
Old 05-09-2003, 06:11 AM
Seon's Avatar
Post
Mor-Drop Axle out of Oakland, CA at (510) 261-1888 sell the 2"-4" dropped front axles for your truck. That's the way to go. Good luck.
