Dropping a 58? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2008, 02:02 AM
GR8 58's Avatar
HotRodGirl
Dropping a 58?
Hi
Has anybody here ever dropped a 58 Chevy? What is the best way to go about it?
Mine is a 4-dr Biscayne with the original 283.
Is it possible to safely cut the coil springs, front and back?
Can you buy lowered springs anywhere or would dropped spindles work better?
Help out the clueless here!
Old 02-20-2008, 06:45 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Dropped spindles are available.
then you can cut a coil from the rear.
Old 02-20-2008, 08:00 AM
lets cut it up's Avatar
Put airbags on that thing and it will get as low as you want and lift up to run the roads and have a nice ride. Cut coils will lower the car but will also make it ride rough. My days of driving cars low to the ground that beat you to death are over. To lower a car IMO, airbags are the only way to go. Tim
Old 02-20-2008, 10:04 AM
wretched ratchet's Avatar
one full turn after it squeeks
Originally Posted by GR8 58
Hi
Never done a '58 but I have done my '55 and it's probably basically the same.
Altho air-bag technology i$ $tate of the art and probably the best way, I like the old school dropped spindles. As far as cutting the coils - - - I promise you, you won't be happy especially if the coils are the originals - - - it is almost impossible to get them even, IMHO. I have no experience with the aftermarket shorter coils so can't help there.
Make sure that whatever you do doesn't create problems with any future plans you may have such as power disc brakes, custom wheels and tires and etc.
Even after putting dropped spindles and power front disc brakes on mine, the right side is ever so slightly lower that the left side but I think it is a weak coiled spring and a rubber spring expander may fix it
Good Luck with what ever you decide.
Old 02-20-2008, 11:11 PM
GR8 58's Avatar
HotRodGirl
Thanks for the replies everyone!
Old 02-21-2008, 03:42 PM
Although they are very rare, GM offered "Air Bag Suspension" as an option in 58. I've only seen one and it was a 4 door. Something was wrong with the system at the time and it sat on the ground. The owner said the system was nothing but trouble. Jack
Old 02-21-2008, 11:52 PM
GR8 58's Avatar
HotRodGirl
Yeah in the one book I read they called it an "unreliable and short lived fad."
Have never seen one here in SA with that option - i wonder if they offered it here?
Old 02-25-2008, 12:27 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
re: Dropping a 58?
Having done it both ways (cutting coils and drop spindles). No discussion. Use drop spindles. Places like CPP (classic performance products) offer the drop spindles alone, or in a kit to switch over to disc brakes at the same time. If you are considering an upgrade, it's cheaper and quicker to do it all at once.
On the airbag solution. Understand that a front end can only be in alignment at a specific height. For proper performance, handling, tire wear etc. you have to pick a height and align it at that height. You would need not only the bags, but some sort of sensor/gauge for each wheel and the ability to stabilize each wheel at the correct height.
Unless you are doing a trailer queen, where only looks count.
Old 02-27-2008, 03:49 PM
claycapps's Avatar
bags are deffinatly the way to go you might want to contact air ride technologies about a bolt on kit . they are kinda pricey but well worth it. they offer a wide veriety of parts for older cars. good luck
Old 02-27-2008, 11:28 PM
GR8 58's Avatar
HotRodGirl
Thanks everybody
Bagging a 58 Ford?? fastrehotrods Suspension - Brakes - Steering 2 05-19-2007 09:41 PM
tinker 58 TINKER58 Introduce Yourself 3 04-14-2007 03:46 AM
58 Apache to 55 KA67_72 Body - Exterior 2 03-12-2007 11:32 AM
Looking for a Truck to hot rod. 59 or 58 chev? ctc1111 Hotrodding Basics 1 06-13-2006 10:10 AM
58 Chevy 2dr Wagon jrpontiac General Rodding Tech 1 02-28-2006 11:13 PM
