Drum brake cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2010, 08:40 PM
Drum brake cylinder
We have been doing a full brake rebuild on the Chevy k20 pickup.
We have replaced everything from the master cylinder,steel lines ,hoses,calipers and all the drum brake parts.
The problem is after getting it all back together the driverside drum brake cylinder is leaking and is not from the flare nut or the bleeder.
So,who makes a good quality drum brake cylinders we used Raybestos cylinders
Old 05-31-2010, 07:32 AM
I guess you guys dont like to fool with drum brakes either
Old 05-31-2010, 08:23 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
A bad part is a bad part take it back and have them replace it.. What's the problem with that ?
Raybestos cylinders,l I though they only did shoes, I have had luck with advance auto and woud think Napa would be a good choice also ..
Old 05-31-2010, 08:39 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I agree return it for another, See where it goes from there probably just a bad part as stated already.
Cole
Old 05-31-2010, 10:36 AM
Irelands child's Avatar
Most likely during assembly someone nicked a seal. I'd take it back. Mostly I use Wagner drum brake parts, but probably all of them are made in China now and in the same factory and by the same people :pain
(let's see, 1 for Wagner, 3 for Raybestos, two for.....)
Irelands child
Old 05-31-2010, 05:13 PM
Well I can except a bad part But it sure is a PITA the cylinder is at the bottom of all those parts last thing to come off and first thing to go on.
Old 06-01-2010, 07:12 AM
pepi's Avatar
If this stuff were easy, everybody would be doing it as I have heard. Besides what else do you have to do with your time .... watch TV .
Consider it the ART of automobiles , a few springs, couple of shoes , two bolts and a nut ... granted the brake fluid can be a pain . But it is not all that bad, it is only a PITA if you allow it to be .. Patience my young friend you can solve this.
Old 06-01-2010, 05:29 PM
Your right brother all I ever really want to do is work on something to me weekdays at work is just waiting to go work on something learn how it works and then fix it.
Disc brake Master cylinder kleen56 Suspension - Brakes - Steering 19 10-08-2008 11:14 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
drum brake spindles modified for discs? Sleeve396 Suspension - Brakes - Steering 13 01-20-2005 12:07 AM
Need help adapting brake line to master cylinder RodFather Suspension - Brakes - Steering 4 01-04-2005 03:41 PM
I'm not even going to try and complain anymore... I'm just a drum brake moron. killerformula Suspension - Brakes - Steering 20 05-25-2004 11:28 AM
