Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drum Brake Question
Old 09-14-2006, 01:12 PM
EazyDuzIt102's Avatar
EazyDuzIt102 EazyDuzIt102 is offline
1965 Impala SS Convertible
Drum Brake Question
How do you adjust drum brakes?What is the best way to do it?I cant seem to get both sides the same.I have a 65 Impala and the brakes always pull to the sides.Sometimes seems like one side is working better than the other.I also took off both drums and had someone press the brakes down.I noticed that only one side of the brake cylinder is pushing out.Its doing it on the passenger side and driver side.Arent both sides of the cylinder supposed to push outwards at the same time?I replaced those cylinders about 2 years ago so they are somewhat new.Any info will be helpful.Thanks,
Eazy
