Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drum Brake Question
Old 09-14-2006, 04:33 PM
matt167 matt167 is offline
Wiki Edits: 31
seized wheel cylinder maby. both shoes should come out with the drums off unless the 2 springs are diffrent colors. hold a screw driver on each side that way you don't blow the pistions out.
