Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drum Brake Question
Old 09-14-2006, 06:08 PM
matt167 matt167 is offline
Wiki Edits: 31
the primary shoe is the shorter of the 2, as they said. some times, tho not common they are the same length by eyeballing them, you have to measure to realize there actully diffrent. putting the shoes on backwards would go togther but it would nearly eliminate the self energiaztion.
