Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drum Brake Question
Old 09-14-2006, 09:42 PM
EazyDuzIt102's Avatar
EazyDuzIt102 EazyDuzIt102 is offline
1965 Impala SS Convertible
Well I got the brakes adjusted and I think I found the problem with why my wheels are shaking when I press the brakes.There is an arm that is connected to the frame that bolts to the tie rods.Well it is loose and looks like it is damaged.Not sure what this part is called.This is the only part I didnt replace when I put my new suspension kit in.Now I remember why,I cant get it off.When you turn the nut on the top the bolt spins with it and there is no way to loosen it.How do I get this part off?I have the new one to replace it but I cant get the old one off.
