Drum brakes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2011, 06:33 PM
Drum brakes?
Where is there a good site to walk u thru installing rear pads and wheel cyl on a 27 chevy 1/2 ton? Thanks, Dana
Old 04-06-2011, 06:34 PM
suppose to read 1972, not 27, sorry!
Old 04-06-2011, 07:51 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Just do one side at a time and use the one you haven't done yet as a reference. Jack up and place on jack stands and remove both wheels and drums and simply do one sid leaving the other side together to look at .JMO
Spray down the bolts and the lines on the wheel cylinders if it's been awhile since they have been off.
Cole
Old 04-06-2011, 11:17 PM
X2 for above. Here's a couple of PDF pages that might help if you get stuck. The wheel cylinders will be bolted on, ignore the part about clips holding them on.
Old 04-09-2011, 08:57 AM
cleaning?
Brakes are done, (all your help was great) I know I can use carb cleaner on my drums to clean them, but my brake shoe (1) got some brake fluid on it, can I use carb cleaner on the shoe also? Then should I scuff my shoe a little? Advise, thanks again, Dana
Old 04-09-2011, 11:05 AM
Wiki Edits: 31
spray it off with carb/ brake cleaner/ saturate it good and it'll clean the brake linings out. do not scuff. that will cause the shoes to grab
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 07:52 PM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 03:07 PM
Weight of Disc Brakes vs Drum Brakes leejoy Suspension - Brakes - Steering 7 06-29-2007 01:41 AM
Help: How-to on Drum Brakes 65Stanger Suspension - Brakes - Steering 3 02-18-2006 07:15 AM
drum brakes mitmaks Suspension - Brakes - Steering 2 07-31-2004 02:59 AM
