Drum Brakes 65 Impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2003, 04:28 PM
EazyDuzIt102's Avatar
1965 Impala SS Convertible
Hey Everyone.Does anyone know how to adjust the brakes on a 65 Impala?I know that there is that Adjustment at the bottom that you turn with a Screwdriver but I have no idea what its supposed to be set on.Also when I push the brakes down,the caliper only pushes out on one side and the other side doesnt move.If anyone knows anything about these kind of brakes,please reply.Thanks
Old 10-07-2003, 05:13 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Eazy,
the adjuster on the bottom of the rear brakes is a starwheel used to adjust the bottom end of the shoes. i usually turn this wheel enough so that when the brake drum is installed it will move freely but you can still feel some friction from the shoes. you don't want it too loose that the wheel will keep spinning, but you don't want it too tight either that the wheel only spins a 1/4 turn. this will cause too much friction and could overheat your drum and cause warping.
on the front end the caliper has one piston. the piston pushes against one side of the rotor. the piston doesn't really move, but pushes the caliper body out, in turn pulling in the pads on the other side of the rotor.
hope this helps.
JB
i re-read your post again. on your second question, are you talking about the wheel cylinders on the back? if only one side of the cylinder is moving then it's probably buggered. you could try pushing it in a bit to see if it breaks free, but you're probably better off to replace it. they're probably only $30 or so, if that.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
