drum brakes on '72 el camino - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2013, 09:39 AM
ok so i have an el camino with 350 and the opitional front disc and positraction. i was wondering if it was worth it to convert the rear drums to discs. also, would it be that hard of a job. I do have two other parts cars, one with front discs. could i take the calipers off there and put them on the rear of my driver (probably not but, hey, a guy can dream)
Old 04-12-2013, 09:42 AM
poncho62's Avatar
Wiki Edits: 5
Rear disks are generally smaller as the fronts do most of the braking.....There are probably kits to convert your rear axle to disks, whether its worth it is another story.
Old 04-12-2013, 10:03 AM
how hard a job would it be if i were to convert? this is kind of a learning project car for me
Old 04-12-2013, 10:18 AM
Banned
don't waste your money..
your el camino has no weight in the rear, the rear brakes do even less than in a car..
if anything get bigger fronts.. if you feel you need them..
many kits (a arms) allow you to put b body 12" rotors on the front..
on top of the willwood kits that put 12-13-14" up front..
Old 04-12-2013, 10:20 AM
Banned
my guess with a 350 your rear is a 10 bolt..
the easiest way to do the rears is either late 70's t/a or catty set up out of a junk yard or the b body cop/taxi rear disc..
Old 04-12-2013, 10:21 AM
Faith - Respect - Trust
The kits that are available are not that difficult to install, if you have a mechanical aptitude...but, as Poncho62 said...is it worth it? You may not get much more braking advantage with rear disc over drum. The front discs that you where thinking of installing on the rear are too big and don't have provisions for an emergency brake.
Ray
Banned
hit up teamchevelle.com for all the facts on this..
Old 04-12-2013, 10:57 AM
alright so i'm thinking just new drums, pads, and probably hoses then
Old 04-12-2013, 11:09 AM
That may not be a bad way to go...a whole bunch cheaper to. Always take a look at your hydraulics as well...wheel cylinders aren't that much money and are a real important part of your braking system. They may even be able to be rebuilt if you have a wheel cylinder hone.
Ray
Old 04-12-2013, 11:15 AM
i'll look at them. thought they looked pretty good when i bought it but that was awhile ago so maybe i'm forgetting. anyway these drums are just trashed as they sit. all gunked up and scored on the inside
Old 04-12-2013, 11:25 AM
Drums today aren't as expensive as they used to be, if they're scoured, replace them...turning brake drums is almost unheard of these days. What you need to do to check your wheel cylinders, is pull back the rubber boot on each end of the cylinder, if they are moist with brake fluid, they need attention...Move the wheel cylinder pins back and forth, (you can do this with the brake shoes on) if they move back and forth freely that means they are OK...one last check, the vehicle is old, try opening the bleeder screw, have someone gently apply pressure to the brake pedal, if brake fluid comes out your good to go...make sure you close the bleeder screw before whomever is applying pressure to the brake pedal releases the brake pedal or you will suck air into your brake lines.
hope this helps.
Ray
Old 04-12-2013, 11:29 AM
Banned
here is a complete rear disc kit.
GM 10 or 12 Bolt Rear Disc Brake Kit w O E Brake | eBay
Old 04-12-2013, 11:34 AM
alright ordering the parts now
Old 04-12-2013, 12:01 PM
Banned
Originally Posted by killeratrod View Post
no e brake.. thats no good
Old 04-13-2013, 08:38 AM
kso's Avatar
kso kso is offline
Think I'm a little late on this if you've already ordered parts but for what it's worth: El Caminos are plenty heavy on back and can use rear discs, it's also always nice to have your rr brakes heat up at the same rate as the fronts. If your using stock fronts I would have used 3rd-gen F body parts, with 12" fronts you might use X-body Seville rears, both available for next-to-nothing, with e-brakes (albeit lame) and practically bolt-on. I always suggest shimming the side play out of the axles first by having shims made to fit under the c-clips so the calipers are not having to move back and forth all the time. Anyhow, been-there-done-that and if you like to drive a little hard now and then it is totally worth the trouble.
Power Brakes upgrade - what is the reason for disc/disc, disc/drum & drum/drum JohnnySkills Suspension - Brakes - Steering 2 10-20-2012 08:44 PM
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 06:52 PM
1967 El Camino Drum to disk brakes Chucky5150 Suspension - Brakes - Steering 4 03-28-2010 09:29 PM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
Weight of Disc Brakes vs Drum Brakes leejoy Suspension - Brakes - Steering 7 06-29-2007 12:41 AM
