Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 04-10-2005, 01:51 AM
nitsud08 nitsud08 is offline
Drum brakes smelling bad
Hello. just bought new brake pads all around for my 67 mustang with drm brakes. i had the drums turned, and i installed everything myself. i adjusted the brakes so the drums would fit on snuggly and still be able to spin. i bought a new master cylinder and installed that too. and i bled everything, and it was all working nice except after i drive it for like 20 mins(in 85 degree weather), it starts smelling like the brake pads. what would normally happen is that im driving down the street, and i stop for a light, and then when i accelerate again after the stop, that is when i smell it. but i just put the brakes on this weekend, so i dont know if there is a certain amount of mileage that the brakes still need to be broken in or anything. this has happened before, the last time i changed my brakes, but the smell ended up going away. i just wanted to make sure this was normal or if i should spend the money and get it checked out at a brake shop. thanks alot
Old 04-10-2005, 02:39 AM
bracketeer's Avatar
bracketeer bracketeer is offline
454 Lemans
brake break in
After installing new brakes there is a break in procedure. You drive slowly and lightly brake to a stop. Progressively increase speed and brake, allowing time for the brakes to cool between braking. This should stop the brakes from getting hot and smelling.
Old 04-10-2005, 06:32 AM
1ownerT's Avatar
1ownerT 1ownerT is offline
re: Drum brakes smelling bad
They may be adjusted a little too snug and are dragging while you drive. Touch the center of the wheel it should be warm not hot with normal driving.
Old 04-10-2005, 01:29 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
I agree with 1owner.
When I redo my '67 brakes, I set them a little loose initially. Use allows the high spots to wear even and the self-adjusters to set themselves.
Old 04-10-2005, 11:50 PM
jimfulco jimfulco is online now
Next time, if you can find a shop that will arc-grind your shoes to match the curvature of your drums, you'll shorten the break-in time greatly, and the brakes will work better right off the bat.
Old 04-11-2005, 05:15 AM
poncho62's Avatar
poncho62 poncho62 is offline
Moderator
 poncho62's barnstar
Wiki Edits: 5
When you smell them, go around and see which drum feels hot.........It may be that the emergency brake is slightly engaged.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Drum brakes smelling bad"
8" and 9" drum brakes FAIRLANE DUDE Transmission - Rearend 2 07-09-2003 09:05 PM
drum brakes 4 straight axle 27trackt Suspension - Brakes - Steering 1 06-25-2003 09:32 AM
Diagnosing Bad Catalytic Converter deleteall Engine 4 04-14-2003 04:43 PM
bad brakes mustangdave Suspension - Brakes - Steering 2 05-28-2002 02:07 AM
rear drum brakes oldcarguy85 Suspension - Brakes - Steering 3 01-08-2002 09:41 PM
