Drum Brakes Spring question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2005, 10:45 AM
JamesRS's Avatar
I have a 72 Chevelle with front drum brakes. The front brake springs seem to be an unmatched set for the drum shoes. (they don't auto adjust) I have a spare 72 10 bolt rear with a good drum brake spring setup on it. Can I use those springs on my front drum brakes, or will there be pressure, adjuster issues?
Old 04-12-2005, 03:31 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
New hardware kits are very inexpensive(less than $10 ea.) and you would be replacing springs that are probabaly 32+ years old.
I looked up the part numbers for the hardware and it list's different numbers for the front and rear brakes, I believe the difference is in the e-brake parts.
Your fronts should have the self adjusters also.
If it were mine I would buy new hardware for all four wheels.
Old 04-12-2005, 04:02 PM
JamesRS's Avatar
Thanks, I found a couple of kits at Kragen, and Autozone. You're right, I'll get new springs for all four corners.
spring question tweaked Engine 7 03-10-2005 11:18 PM
New Drum Brakes Dasoldier Suspension - Brakes - Steering 1 05-22-2004 04:15 AM
Drop Spindles for Drum Brakes? Echofive Suspension - Brakes - Steering 3 05-17-2004 04:21 AM
4 wheel drum brakes. Super Chevy Suspension - Brakes - Steering 8 05-11-2004 06:23 AM
Drum Brakes astrops Suspension - Brakes - Steering 14 05-10-2004 10:54 AM
