-   -   Drum to disc brake swap (http://www.hotrodders.com/forum/drum-disc-brake-swap-222284.html)
bfhduh 07-29-2012 11:00 AM
when swapping the stock drums with a stock disc rear end do I need to use a different per portion valve in a 1991 s10 with a 350 400 turbo
Ripper 410 08-02-2012 10:15 AM
Yes I would suggest finding one off of a camaro,or firebird 84-2000 with 4-wheel disk they are plentiful and are the simple to adapt to your application and are also close to the weight of your app.
Ripper 410 08-02-2012 10:18 AM
that is unless you can get the one off the vehical the rear came from
OneMoreTime 08-02-2012 01:08 PM
You will need an adjustable proportioning valve as the factory valves will not have the correct bias front to rear..The do a et up routine on gravel until you get equal braking effort front to rear..
Sam
bfhduh 08-20-2012 09:01 AM
I got my rearend in and my timing adjusted and everything seems to be fine without changing my perportioning valve just though I would let u guys know
